Thread: best truggy?
squeeforever
squeeforever's Avatar
11.21.2007, 02:31 AM
Granted you start with a LSP-R and go brushless, there is a ST-R arm convertion that basically changes the way the truck drives. It consist of HB buggy towers, ST-R arms and driveshafts, ST-R c-hubs, Mugen tie rods, the factory LSP knuckles, different springs, pistons, and swaybars. That right there eliminates alot of the usual mods like converting to 17mm hubs (ST-R shafts are 17mm, so no need to convert anything with the ST-R setup). That in combination with a few of the usual hopups like CF rear brace, HB CNC buggy front brace or two if you have room, and a few other things like the HB GTX heavy duty diff cases and doubled up ackerman plates. Thats mostly it.
