Patrick
Patrick's Avatar
11.21.2007, 10:09 PM
Originally Posted by t-maxxracer32 View Post
was looking at this battery tray maybe to buy for it...
http://www.rc-monster.com/proddetail...MFPbatterytray
also do you think it would fit the true-rc 8ahs?
It says it fits the flightpower 5000's, which are 166mm x 44 or 45mm.
The older 10C true rc packs will fit length ways, but they're 50mm wide, so they probably won't fit.
The new 15C versions will fit length ways and they're only 45mm wide, so they should fit in the tray. The new 15C packs are a bit taller and heavier than the 10C ones, so keep in mind that it's going to be a big chunk of battery to have on one side of the car. Their also more expensive than the 10C ones, and won't be that much cheaper than the Flightpower 5s 25C 5000mah packs.
Are you buying new batteries or do you still have some from before?
