glassdoctor
TEAM FUSION
glassdoctor's Avatar
11.22.2007, 01:24 PM
You probably need to dial out more of the brake on the radio or MM software. Normally you only need the brakes set at like 20%...
Once you get it dialed out... you can grab full brake and the car will have just enough to get the job done, not too much that it locks up all fours or spins out. It makes it much smoother and easier to drive. With this setup, a quick tap of the brakes will be a subtle thing and not a violent one.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
