Originally Posted by nl12
Do you mean the bore is too big causing the pistons not to fit as they should? I dont understand.
This is the word on them. Many have complained about the fit.
A secondary effect of the larger tubes with the sloppy fitting pistons is shaft slop that causes perpetual leaking.
One of my buddys said that if they leaked any more then they do he would need to get them a shot of penicillin.
