mgm 16018, is this normal?
ncalenda
Need for Speed
ncalenda's Avatar
mgm 16018, is this normal? - 11.24.2007, 10:42 AM
I have found 2 things that seem odd and wanted to see if this behaves the same for others...
1. When I have the LVC set to shut down once the lipos are low, I notice that the truck will start to cut out as I drive it after about 10 minutes. To confirm this setting causes this, I changed the setting to reduce speed, and the cutting out goes away.
If I put them in my rustler, the lipos will run another 15 - 20 minutes. When I put a voltage meter on them, the 2S was at 7.68 Volts, the 5S was 11+.
I use MaxAmps 6000 & 8000.
My thought is that under load the voltage may be dropping below the LVC point, and it causes it to cut out.
2. The brakes are strong, I have them set to the softest point, but when I use them, I have to move the throttle really slow. I also set the end point on the radio to 60%.
It doesn't seem to be proportional, I wonder if I should re-program the radio?
Anyone seeing the same things?
  Send a message via AIM to ncalenda
