11.24.2007, 02:10 PM
jnev, you propable should list some of the stuff he will use the welder for, so we could help you chose something to fit the application.
1/16" to 1/4" mild steel seems to be the most common building material. If this is the primary thing to be welded you'll want a mig (wire fed welder).
1/4" to 1/2" you'll want a stick welder.
1/16 and down or super nice quality welds (1/16 to 1/4") you'll want a tig (heli-arc). But they are expensive!!!
I would recomend a Lincoln or Miller welder, mig-tig-or stick.
If you get an economy mig welder just make sure you get a "gas kit" for it as the flux coated wire SUCKS!
I should have put a $3600 Miller Syncrowave 250DX on my wish list, hehehe.
