superlightmaxx
superlightmaxx's Avatar
11.24.2007, 09:23 PM
I too considered using tape to mount them but the foam was to thick to provide the low profice they are supposed to have so i trimmed the foam with a blade. Removed about 1/3 of foam thickness. much nicer look and I think if you dont trim the foam they will be a lot more wooble cause the foam is to compressed inside... that the number one reason I trimmed mine.
Working on:
Twin CF GorillaMaxx (8S motors on 2x2slipo)
2WD AL. GorillaMaxx (7lbs with batteries)
