Matthew_Armeni
Matthew_Armeni's Avatar
11.26.2007, 05:36 PM
Originally Posted by mabu View Post
I know - i already run a 8L in my EMaxx ... it gets hot all the time.
I already ordered a motor heatsink clamp :)
Well i read that the maximum length with the tekno mount is 74mm, the length using the heatsink is about 76mm
Trust me it fits, it's what I am currently running. You just can't run the motor in the low cg mount setup. By the way, are you running the extended rear a-arms?
  Send a message via AIM to Matthew_Armeni
