11.26.2007, 10:28 PM
I ordered some 80 Watt tecs from Ebay.. foot print seems small.... only 40mm x 40mm x 3.2mm.. advertised that it iced up in 30 seconds...Probably @ max load/setting... I would run a seperate battery pack to it.. probably A123s, since they charge very fast... and might just run 6 or 9 volts off of it... The picture looks like that both sides get cold.. I wouldn't want it to freeze.. but it should be better than cooling it... I'm gonna shave a heatsink off the motor and ESC to see how it runs... and might put a 3rd channel switch to turn it on when motor temps gets hot...
