Thread: Wich charger???
aqwut
Brushless Heavy Weight....
aqwut's Avatar
11.27.2007, 09:50 AM
Do you have links that you can show where to purchase these balancers? What on line companies sell them? What brand name are they under? Thanks Guys.
allerc.com or unitedhobbies.com
the 1210i is awesome, and I do have one.. but I'd rather have two 610i networked together to have 500 Watts of charging power... :) This is good for when you have high voltage/high capacity Lipos and want to charge @ 2C.... 1210i is able to charge 12S @ 4Amps.... or (2) 6S @ 2 Amps Each... 610i could charge a 6S @ 11 Amps... so you could easily charge a 6S1P 5000mAh in a little more than half an hour(that is if your lipo is able to charge @ 2C)
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
