Mamba max getting HOT fast!
rootar
rootar's Avatar
Mamba max getting HOT fast! - 11.27.2007, 02:06 PM
i dont have a temp gun but i can only hold my finger on the heat sink for 3 secs after only running for 2-3 minutes, I installed the CC UBEC last night and it didnt help the problem, still very hot, its 45 degrees outside and the motor (Feiago 9l) and mambamax temps are WAY up there, my battery (3s 5000 maxamps) is not even warm at all, its almost as cold is the temp out side. Are these kind of temps normal? im gonna get a temp gun asap but what can i do to get it to run cooler? im taking the plugs to the motor off and direct soldering them, maybe this will help and little bit with the low speed cogging but what about temps?
