MetalMan
MetalMan's Avatar
11.27.2007, 05:02 PM
DANG i bet thats what it is! i thought i needed to trim those some because i knew theyd be close but they could be touching.
ill check and cut my motor screws off 1st and then see how it goes from there.
It shouldn't be a problem if they are just touching. The windings have a coating on them (epoxy, I think), on top of the normal insulation they have. So to get to the bare wire you'd have to push past the epoxy and thin wire insulation. But it's very possible that when the screws were tightened down the wires were punctured.
