Topspeedtimmy
trick mad power (tmp)
Topspeedtimmy's Avatar
11.28.2007, 11:54 PM
So 0.8p metric is exactly the same as 32 pitch? The Jato gears idea sounds good.
On the other Revo, would a 6xl on a Traxxas VXL ESC powered by two 3s lipo packs in parallel be any good in terms of power and heat?
I would think the VXL would be able to handle the amps being rated at 200 amps constant.
The other possible set-up would be dual Velineon systems each powered by a 3s on an E-maxx trannsmission, which would cost more but it would most likey run cooler and faster.
