Matthew_Armeni
Matthew_Armeni's Avatar
11.29.2007, 07:10 PM
The VXL won't fit the Tekno conversion unless you get an adapter for the shaft, the elektri-clutch needs a 5mm shaft to work and the VXL is 1/8 in. Neu's are definitely better, they just cost about 3 times as much as Feigao's. Brian's right, a higher voltage setup with a bigger lower kv motor is a better way to go.
  Send a message via AIM to Matthew_Armeni
