11.30.2007, 12:51 AM
If you're buying a 4s1p pack, then you can connect 2 in parallel. What vehicle are you putting this in? I've got a a MM, 8XL, and 4s2p A123 in my truggy, and it's currently geared for 40 mph.
If it's in a Revo (I'm guessing from your name), then you should be able to get a similar speed as long as you parallel the packs. If you use 4s1p, then the voltage drop under load will probably result in the loss of several mph.
