rckcrwlr
Where are the Rocks????
rckcrwlr's Avatar
11.30.2007, 10:52 PM
Originally Posted by Patrick View Post
Because 21V is what you'd put in the calculator if you were using 6s. 5s comes off the charger at 21v, but when you put load on them the voltage will come down. 5s is 18.5v nominal, and for the calculator, use maybe 17-18v. Good batteries will hold their voltage better than lower quality batteries under load.
I don't know why it kept defaulting to 21V. I put in 5 cells at 3.7V each...It came up 18.5...I will try again to see...
Here it goes...
Vehicle Weight (approx): 10
Desired top speed in MPH: 40
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1.6956521739130434
Additional Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 14
Battery Voltage: 18.5
Tire Diameter (inches): 7
Total Ratio: 18.42857 : 1
Tire Circumference: 21.991 inches (558.575 mm)
Required Motor RPM: 35397.099 RPM
Required Motor KV: 1913.357 RPM/V
Good Motor Choices:
BK Wanderer 10 XL (kv=1668)
BK Wanderer 9 XL (kv=1853)
BK Wanderer 8 XL (kv=2084)
Better Motor Choices: No motors of this class fit the parameters you entered.
Best Motor Choices:
Neu 1515 1y (kv=2200)
Neu 1515 2.5d (kv=1700)
Neu 1512 2.5d (kv=2000)
Neu 1512 1.5y (kv=1900)
Neu 1512 3d (kv=1700)
LMT 1940/9 (kv=1742)
LMT 1940/8 (kv=1959)
Neu 1521 1.5d (kv=1860)
LMT 1950/8 (kv=1634)
LMT 1950/7 (kv=1867)
LMT 1950/6 (kv=2178)
Bought my Wife a Rock Garden :027:
