12.01.2007, 01:41 AM
I went back and read over the "red cat" post and studied the pictures a bit more.
Can you get shorter CVD's for that setup?
I'm with John on his recommendation. The Scorpion 3032 motors would work well also. There are two ways to increase starting torque with a motor change. Increase stator diameter OR increase stator length. All the Scorpion 30xx motors use the 5mm shaft.
Thanks for the recomendation. I can always cut and weld my center dog bones to the correct length if needed. A longer stator would be the best bet for this setup as it needs some more torque. Does axi make a similar sized motor to the scorpion 30xx motors? Which scorpion/axi would I want to use? Thanks a bunch for the advise, I have plenty of inrunner experience, but not a wholelot of outrunner testing under my belt!
