12.01.2007, 02:38 AM
Originally Posted by johnrobholmes View Post
Lpimp- The 3032 is almost 8 ounces. It will be plenty of motor for most any smaller builds, and very robust from the front ring bearing. Think of the motor weight about the same as an inrunner. You would want 6 ounces of motor for a stampede, so stay with that same heft and maybe add a bit since you will lose gearbox weight. Motor weight is a pretty good indicator of how much power it can produce.
Ok, but I would like to have a lower kv motor, somewhere around 600 - 650kv, so that I can power it with 5s and run taller tires. Not looking to do 70mph, something in the mid 40s with good low speed driveability and less heat production than the current motor.
