Mailman
12.01.2007, 09:09 AM
Xray is really big into chassis flex. Check out there on-road cars, they are designed so that you can change the handling characteristics by adding or removing certain screws to add or take away chassis flex. It is really helpful if you are running a touring car with rubber tires on asphalt or carpet. With foams on carpet you want your car pretty stiff, but with rubber the chassis flex adds grip.
