sikeston34m
sikeston34m's Avatar
12.01.2007, 11:18 AM
Originally Posted by johnrobholmes View Post
Choose the 12 turn then, or wind your own for even higher voltage handling. They come in kits too. I don't think changing the Kv will change the max usable height of tire either, only the motor size and voltage used. Time will tell on that though.
http://www.innov8tivedesigns.com/pro...products_id=83
The winding does have alot to do with how much torque she makes.
In comparing this, think about the "turn" ratings on brushed motors. The fewer turns meant you had a high speed motor. If you have many turns, then you have a low speed motor that makes more torque.
A "Race" motor in the 540 size might have as few as 4 turns. But a Lathe motor for a rock crawler might have as many as 30 turns.
Remember the "wrap the wire around the nail" experiment? How did the number of wraps affect amp draw and how strong the magnet became?
Last edited by sikeston34m; 12.01.2007 at 11:43 AM. Reason: PS I noticed the 4130 starts a little better than the 4120 in this setup on the very same voltage. 660kv versus 305kv
