sikeston34m
sikeston34m's Avatar
12.01.2007, 03:13 PM
Originally Posted by aqwut View Post
What's Amps is that motor rated for?...
Here are the specs from the Manufacturer's website.
4120/14 Specifications
No. of cells 12 - 16
4 - 5 Li-Poly
RPM/V 660 RMP/V
Max. efficiency 85%
Max. efficiency current 20 - 40 A (>82%)
No load current / 10 V 2 A
Current capacity 55 A/60 s
Internal Resistance 41 mohm
Dimensions (diameter. x lenght) 49,8x55,5 mm
Shaft diameter 6 mm
Weight with cables 320 g
The addition of the cooling fan increases it's current handling ability I believe.
