NeuMaxx
12.01.2007, 11:51 PM
I got a little problem. My case are too tight. The bind with no shims. I have tried putting the internals in the other case but the problem persists. Is it possible to grind the case so that the bearing will sit a little deeper? Is there a head for the Dremel that fit that bearing hole?
