david lamontagn
12.02.2007, 03:17 PM
It does get hot on low speed running, right at the speed that the clutch is still slipping
Hey James, do you use the clutch shoes mount in leading postion, or you use it in "normal" position?
When my buggy will be done, i'll try it without the spring, so it'll suppose to engage at verrrrrrrrrrry low rpm and not supose tu overheat
