sikeston34m
sikeston34m's Avatar
12.02.2007, 08:08 PM
One thing that I thought was very interesting is at the bottom of that page. It's how to figure the kv of any motor that's already built.
"Drive your motor with a power drill.
Measure RPM and voltage generated.
Kv = RPM / voltage"
I spun the 4130 at 930rpm with a drill. It was feeding 2.9 volts into a volt meter on the AC scale.
930rpm/2.9volts= 320kv
Pretty close to the factory rating of 305kv! Which maybe with the load of the motor, the drill wasn't quite spinning at 930rpm. I think this is a good quick method though.
