highflier
Emaxx- FLM wannabe
12.03.2007, 12:22 AM
Thanks,
I want to stay 3s since I am zip charging and it only takes 10 min for a charge :)
I also don't want the weight or size of the packs to grow at all. I just had to reconfig the layout to get the 3s A123's in. Now I got to find a good way to secure them if I cartwheel. I am sure they will say in place with Velco for the normal bumps and jumps.
I'll pick up a 19 pinion. That should help quite a bit. I think the ESC will be fine since it is rated 70Amps at higher voltages. I'll probably set the throttle on my radio to 90% or so anyways. The slipper will not be able to handle that much power. I already destroyed the diff once when I was using 3s lipo's.
Highflier
