sikeston34m
sikeston34m's Avatar
12.03.2007, 07:31 PM
Originally Posted by marc993turbo View Post
Hallo,
i need a controller for my pletternberg maxximum which goes into my new slipperential/g-maxx babe :-).
I thought i will give the quark monster pro 125 a chance it seems to be a good controller.
Iīve one question: Does anybody use the quark with A123 Cells? Is the Quark programmable so that the LVC will _NOT_ kick in to early? Donīt get me wrong i do not need a LVC for the A123s i just want to shut the LVC off.
One can configure quite a bit regarding LVC (i just read the Quark Manual) but i donīt see a possibilty to shut it off.
I donīt understand how the Quark determines who many cells are connected to it and how it calculates at which voltage it shuts off.
To make it short - does anybody use the Quark Monster Pro with A123s without problems?
Thanks for some help!
Marc.
I use the Quark 80amp ESC and A123 cells with no problems. The 80 amp and the Monster Pro have the very same settings.
I set the Lipo cut off to it's lowest setting of 2.2 volts per cell. A123 recommends a 2.0 cutoff for their cells, but by the time they hit 2.2v per cell, they are pretty much done anyway.
The discharge curve is very flat for A123's.
I hope this helps.
