ssspconcepts
ssspconcepts's Avatar
12.04.2007, 12:15 AM
One note on Mike's CRT.5 chassis...its not a big deal, but I did have to dremel grind a little bit around the front dog bone (mainly the ball) that is included with the kit. The main reason is because the dogbone that mike includes in the kit is beefier than the stockers. If you don't have a dremel or aren't handy with one...then you could order a second rear dogbone for about $8 from Ofna since it is exactly the same length as the CRT.5 EXT chassis front dog bone.
