08.16.2005, 11:14 PM
Its really going to be hard to keep it below 70 amps. I don't have a huge amount of experience with 12 and 14 cells. From testing using the Eagle tree an XL 3100 on 12 cells will peak at 115 amps and pull almost 80 constant. Also tested on 12 cells were 9L,7XL and basic 4300. All pulled about the same amps on 12 cells as the 3100 if you can believe that.
Its hard to say which motor would pull less than 70 amps constant. Maybe a slow turning basic motor? Sorry I can't be more help. But the 9920 would be a better choice for the E-maxx.
Thank you,
Promod
