Thread: Crt.5 ext. pics
ssspconcepts
ssspconcepts's Avatar
12.04.2007, 07:29 PM
Originally Posted by dark96 View Post
I was wondering what a good size gear to run with a crt .5 electric conversion. I'm gonna be running a 6000mah 3s maxamp lipo on a MM 5700.
I am running 3S 5000mah Flightpowers (and sometimes 3S 3850mah Thunderpowers) with a Neu 1509 1.5D (4500kv). My gearing is 15/46. I understand others are running the same setup except they are using a 7S Nemesis motor and the gearing for them is 12/46...either should work fine and keep your temps in check.
