sikeston34m
sikeston34m's Avatar
12.05.2007, 08:41 PM
Originally Posted by MetalMan View Post
Blue medium strength is what I use on everything. It's already on the set screws holding the shaft, and on the set screws holding the cups to the shaft (and on the end of those set screws).
The E-Maxx output shaft, if 67.6mm long, is actually just about the perfect length for the motor. However, it's got that big chunk of metal in the middle, which would take a while to turn down or cut off.
That big chunk comes off pretty quick if you put it in a cordless drill, then hold it against a Bench Grinder. I take my time and don't get it too hot. Just stopping occasionally to cool it with cold water. Get it down close, then use a file on it to rough cut some more, and final polishing is done with sandpaper.
You might be surprised how fast this little procedure is. I removed the center "chunks" from two of the Revo Output shafts, fully prepped in about 30 to 45 minutes or so.
