Topspeedtimmy
trick mad power (tmp)
Topspeedtimmy's Avatar
12.06.2007, 01:10 PM
I think I hit the sweet-spot gearing wise. It's got just enough speed, and the temps are really low, though it was 40-50 degrees outside. The ESC would probably be 30 degrees hotter if it was 80 but that's still not too hot. As far as rpm it seems to be running well, it spools up fast and hits top speed quickly and doesn't seem to be very bogged down even in the grass.
It was able to do wheelies on my very first run when I had the slipper really tight, even up to 5 mph rolling wheelies. I loosened the slipper for the run caught on tape, but it was a little too loose and would slip alot under acceleration. My next video I will try to get some wheelies and maybe a little off-road action.
