sikeston34m
sikeston34m's Avatar
12.08.2007, 12:05 AM
Ok, here's the new setup.
1. Quark Monster Pro 125 amp ESC - I added a 2700uf@25volt 105C Low ESR Cap to the power lead. It's a Novak product. It adds plenty of crackle when I plug the batteries in.
Also added is a Micro Toggle Switch. I like it better considering my mounting options.
The motor leads AND the ESC Power leads have been shortened. Also used are the connectors that came with the ESC. They are much larger and more up to the task than the previous 4mm connectors.
A Nice coat of Thermal Heat Sink compound was applied to the ESC before it was strapped in. This should provide the best heat transfer possible to the aluminum mount.
2. CC 10 amp BEC module - This is good for up to 6S Lipo with how it is currently wired.
