12.08.2007, 12:52 PM
The outrunner has plenty of torque to push it geared for 60mph. When you do tire/battery changes, let the starting behavior show you the limits.
With the Revo, I have noticed if I "blip" it to about 1/4 throttle just for an instant, then back off, it starts great.
It doesn't seem to like trying to start with that first small step on the trigger.
Aaah, Rain, Rain, go away. I wanna take my Revo outside and Play.
I noticed the same thing with my outrunner setups, a quick blip gets it moving and as long as it is rolling small throttle inputs work fine. I wish the quark had an adjustable throttle curve like the mm. You could give the curve a sharp rise at the beginning and then level it out again. I think that would given the motor enough "kick" to get it moving. Just ordered a fan for the axi and when that comes in I will rearranege the chassis so that the battery can lay flat. I will also try larger tires before I do anything and see how that works.
I know what you mean about rain, it rained here yesterday and it is so nasty and humid outside now.
