12.12.2007, 09:11 AM
i was thinking a small aluminum wedge cut out of a block and CA that to the rear L mount where it sits flush on the chassis and is "snug" aginist the back edges of the heat sink/clamp which DOES actually support the motor because i bolted it all up and it held the motor perfect and it was easy for me to get my short little motor screws in the front. So you and I are thinking the same thing right? if i do put a very mellow wedge it will be almost as if sitting on a solid alumnium cradle mount to the frame.....
