12.12.2007, 10:58 AM
Originally Posted by Gee View Post
I didn't know that, but won't forget it now. Thanks Brian for sharing it. Anytime you want to pass some of your knowledge and experience this way. I'll take it.
What will the larger shaft/rotor do for the Novak setup?
No problem.
A larger shaft will be harder to break. Depending on how you drive and the amount of chassis/motor mount flexing, you can get some pretty decent lateral forces on the pinion, which could snap if using an 1/8" shaft.
A larger rotor allows for larger/stronger magnets. But, if I read NovakTwo's post correctly, the rotor won't get bigger, just the shaft.
