ssspconcepts
ssspconcepts's Avatar
12.13.2007, 01:23 PM
You might find Finnsters thread about his 11.5lbs (5.2kg) Revo with 10s1p A123 (equals 8s lipo), MGM 9032 and Neu 1515/2y (1100kv) interesting.
Depending on your final wheight you should even be good with an MGM 9032 which should be able to provide 2.5KW cont with 8s lipo (28Vx90A) and even more (didn't found it's burst capabilities). I run a 10.8lbs truggy with 10s1p A123 with a 65A rated ESC and my max power output is at 2.3KW. This car is overpowered and pulls wheellies with a center diff. All this combined tells me a MGM 12032 would be more than enough for your needs. A MGM 9032 should also be plenty.
Thanks I appreciate you sharing the information.
