Spin-up -
12.13.2007, 10:46 PM
I've been following this thread as I continue to experiment with my e-maxx. I'm starting to think that a centrifugal clutch might be just the answer. If the outrunner's only real problem is startup, why not let it "idle" like a nitro (just set your throttle trim up a little) and then just grab all the throttle you want to take off. If you can't really use the ESC brakes on a direct drive anyway then it seems like a natural fit, no?
