MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
12.14.2007, 12:03 AM
Love the ESC Mount. Looks like it will work for the MM or MGM very well. An idea though...If you make it a little bigger you could make it a perfect size to use as a Quark heatsink too. Just make it the same size as the quark case.
I like it too. It's always hard to find a good spot for the esc. That spot looks perfect other then possible damage from shock tower flex. Shouldn't be a problem with the shocks mounted in front of the towers like in the pictures. I'm using plastic towers and they can bend a massive amount in a bad landing.
