Best Truggy Diff Pinion Bearing?
sikeston34m
sikeston34m's Avatar
Best Truggy Diff Pinion Bearing? - 12.15.2007, 02:10 PM
I'm finding the limitations of the bearings in the truggy diffs.
With the spiral cut gears of the 4.3:1 ratio, the pinion not only side loads the bearing, but it also pushes or pulls against the bearings.
I've been using steel ball bearings and they aren't holding up to the increased torque levels of my setup.
I could hear the diff Pop occasionally in the rear under hard acceleration. I took the diff back apart, and found alot of slop in the bearing closest to the pinion. I swapped positions with the two bearings, reshimmed to take all the play out and it worked perfect.
Now about 4 runs later, it's doing it again. On 6S, it will do 60mph+ and top out very quickly. With NO slipper, the setup is able to transfer all the torque that the motor will make. Which is alot!
A needle bearing with thrust bearing type qualities would be ideal, but I can't find any in this size. 8x14x4mm.
Is Ceramic Nitride the toughest out there in a ball bearing? like this one:
http://www3.towerhobbies.com/cgi-bin...?&I=LXPVB1&P=7
