New to brushless 1/10 scale. Help!!!!!
pizzaman
New to brushless 1/10 scale. Help!!!!! - 12.17.2007, 02:48 AM
I just bought this truck on EBAY(sorry, I just pasted the ad) and need to know which ESC/Motor combo to choose. I currently have 2maxamps 11.1v 5000mah lipos that I would like to utilize. Not so concerned about $ just dont want a Novak.
Maximizer RRP Diffs: $68.95x2 (Front and Rear, Alloy Cups with RRP Steel Ring & Pinions) ***
Pro-Line Steering: $33.99 (Integrated Servo Saver is both tighter and smoother)
MIP (Pro-Line) CVD’s F/R: $20.00x2 (No broken axles... EVER)
MIP Center CVD’s: $45.00
RPM Bearing Carriers F/R: $25.00x2 (Bigger bearings take abuse)
Newer 3.3 Bulkheads: $6.00x2
Aluminum Servo Horns: $9.99 (Blue anodized for steering/shift duty)
Traxxas Lightweight Internal Shafts: $10.99
RRP Clutch w/ Steel & Plastic Gears: $36.99, $7.59 (Better than the REVO clutch by far)
Unlimited Engineering Idler Gears: $32.00
Big Bore Shocks w/ Nitride Shafts: $63.99 (Smooth and no blowouts like the stock ones)
Lunsford Ti Hinge Pins: $21.79 (These won't bend like the stock screw-pins)
Trinity Dual-Stage Springs: $13.60x2 (A little stiff, might need to tune them a bit, stock springs also included)
Pro-Line Bumpers: $9.99 (Discontinued and hard to find)
HPI Super Mudder Tires: $26.99x2 (These tires are AWESOME)
RRP Pinions: $3.09 each (a few included, also the stock 18T Traxxas ones included)
GorillaMaxx battery straps: $14.00
Traxxas Differential Spool (NIP): $10.99
Lunsford Titanium Fat-Boy Screws for the motors (NIP): $7.99
HPI Rubicon Body: $20 + Paint. (It's a little rough now, bu
