BL-Power
BL-Power's Avatar
12.17.2007, 11:34 AM
well i was thinking about the MM and the polyquest 4s lipo. with a 30-50c discharge rate, that should be enough to make it really move.....right? i might use the $275 quark controller. but i was thinking about the kontronik jaxx 80-6-18. would that be a good choice?
I am also using the Jazz 80-6-18. Its really good controller, and it peforms very well, i've never had any signs of cogging. If you use a data recorder, you will see that you can't get more than 1300watts out of it on 4s Lipo. I am using mine on 6s Lipo and i have peaks up to 2000watts an the Jazz is still cool like a stone
Its a very nice controller
 Send a message via ICQ to BL-Power
