12.17.2007, 12:38 PM
well i was thinking about the MM and the polyquest 4s lipo. with a 30-50c discharge rate, that should be enough to make it really move.....right? i might use the $275 quark controller. but i was thinking about the kontronik jaxx 80-6-18. would that be a good choice?
Go quark, or the kontronic. The MM will not run the align 600, or any other outrunner(save for crawler apps). The quark works well for me, I actually used the roadster 65 on an align 600l in a 2wd emaxx. I would say that if you are going to run 5s that you could use the quark 80 or a mgm 90 amp esc to save some money. The align motor will not spin very fast on 4s so you will have some high gearing, and most likely need an esc with over 100amp rating. I ran my emaxx on 4400 5s 20c lipos and they stayed cool, as did the quark 65 and the motor. It was geared for around 40mph.
