12.19.2007, 07:51 PM
Hey Crazy, I have run a similar sytem in my LS10 for a while. I have a maxamps 3000 5s pack and a quark 65 roadster. I am using a hacker c50 13l motor, but have a 15l to swap into it. Tons of power and great runtimes and cool equipment! Hv setups are the way to go. I could almost go down to a 2100 5s pack, or go up to 6s and gear it way down. I am slowly try to chane over to 5s and up as the benifit is very noticeable. Pack size and weight do become an issue, but there are quite a few small cells with good dimensions that can be use, plus you can always break up the pack and place them in different locations on the chassis. The crt.5 does not have much real estate, but I am sure that you can find a way!
