12.20.2007, 11:46 PM
I am right there with you on the baja ss kit David. I need to sell a few cars and I may get one in the new year. Proline released the badlands rear tires for the baja, I would love to see that tear up the baseball feild next door to my shop!
I need to post up my current project. I am using the tekno clutch adapter with a 4tec 2 speed clutch bell on my yusa rally chassis (like the inferno gt). I had to make a custom spacer to get the two spur gears at the correct distance for the 2 speed spurs. I am also using an integy 3 shoe flywheel kit with al shoes. We will see if it can hold up the the increased load that the car can place on it. I would like to see an 1/8 scale clutch adapter, maybe tekno could whip one up!
My main purpose for the clutch is to allow the use of a MM with my aveox motor. The aveox motors have similar issues with the MM as the neu motors do. Plus I am running some tall gearing, 15/48 1st gear and 20/44 2nd gear! The clutch should help the aveox pull the tall gearing without cogging on startup. This car should be good for 65+!
