NovakTwo
Senior Strategist
12.21.2007, 12:16 PM
Originally Posted by austinmaxx View Post
when you try to slide the pinion on the HV motor to line up with the spur the motor shaft is not long enough...the new e-maxx has more space between the spur and motor now..., a pinion that has a longer shaft might work ,,,here is a link to 5mm long shank pinions http://www.megamotorusa.com/ look under new stuff and scroll down
Any ideas?
We just became aware of this length issue yesterday, from a comment on the Traxxxas E-Maxx forum. We have a new E-Maxx on order and will post updates concerning whatever re-designs to our HV motor will be necessary.
We were made aware (earlier) by Traxxxas of the rotor shaft diameter issue and are presently tooling up and testing a new 5mm shaft rotor and endbell assembly for our HV motor. I will check with our design team and post updates on the forums as more information becomes available.
I realize that many customers have our HV systems that were designed as a drop-in brushless replacement for the original E-Maxx. Novak is committed to a re-design that will make our HV motors compatible once again.
Novak Electronics, Inc.
