Dafni
Dafni's Avatar
08.20.2005, 04:15 PM
Thank you for the suggestion, Metalman. I saw this BMS servo, too. I already have a 0.15 sec servo, and you're right, actually this is good enough. But maybe I'll try a faster hi-torq one day.
I also saw this interesting piece of info in the BMS describtion:
WARNING: Using the servo arm to turn the servo may cause the gears to break or jump and the servo will stop functioning correctly. This is true for all servos regardless of servo manufacturer.
I always thought this turning by hand can't be good. Always tryed to avoid it, but it happens all the time when you wrench on an RC (or is it just me??)
