12.23.2007, 02:01 AM
Hey Linc,
I'm Brain Storming again. LOL
Correct me if I'm wrong, but since the new E maxx has a Revo Style Slipper, won't the Revo Mod 1 Spur fit this?
I wonder what the gear ratio is inside the tranny from input shaft to output shaft?
I'm thinking gearing it high like this will be best because the outrunner will make so much more torque than both the Titans. Then add the 2 speed kit to the equation. We've got Gears!
What do you think Linc?
Revo spurs will fit, not sure if the tranny has enough clearance for the out runner with the 20t pinion, so i stuck with the 25 for my number crunching.
Ok, intelligent guess says that the internal ratio is 33/18, or 1.83:1. All guesses referenced from the new emaxx parts list on the traxxas website, hope it is correct.
This appears to be slightly lower than the old emaxx second gear. That coupled with the use of 14 cells would account for the higher speed while still using the same diff ratio, tire height and motor kv.
Traxxas is smart, they reused the idler gear, still 20t but steel now. Good cheap way to up grade an old emaxx tranny!
Motor kv on the titans must be arround 2200, yeilding 35mph on 14 cells. This sounds too high, as most belive the motors to run around 20k rpm on 14.4, which would be 1400kv or so. Heres the speed calc for the stock setup, my best guess on motor kv:
Differential Ratio: 2.8461538461538462
Transmission Ratio: 1.83
Other Ratio: 1
Spur Tooth Count: 68
Pinion Tooth Count: 19
Total Voltage: 16.8
Motor KV: 2200
Tire Diameter (inches): 5.75
Spur/Pinion Ratio: 3.58 : 1
Total Ratio: 18.64081 : 1
Tire Circumference (inches): 18.06 inches (458.83mm)
Total Motor Speed: 36960 RPM
Vehicle Speed: 33.92 MPH (54.48km/h)
Now here is your proposed setup with the 25t pinion:
Other Ratio: 1
Spur Tooth Count: 40
Pinion Tooth Count: 25
Total Voltage: 14.8
Motor KV: 900
Spur/Pinion Ratio: 1.6 : 1
Total Ratio: 8.33354 : 1
Total Motor Speed: 13320 RPM
Vehicle Speed: 27.34 MPH (43.92km/h)
Looks to be a bit slow on 4s with that combo, but most likely not too far from stock. Would be better on 6s, at least for me.
Give it a try Sike, and let me know what you think. My math may be wrong, but I checked it a few times?!
