Originally Posted by sikeston34m
If the Mesh will line up right, we could use a 36 tooth spur instead.
The would give a 1.44 ratio instead of a 1.6
This outrunner will make about 900 watts, so I'm thinking the acceleration should be there.
Another option would be to go with the 2826/8 motor. It's a higher kv at 1130kv.
The mod 1 gears are alot tougher than the 32 pitch gears aren't they?
Mod1 is quite a bit stronger, the 36 tooth would help. I only had the voltage set on 14 cells to try and figure out the titans kv. Traxxas claims 35 mph so I figured I would run the numbers. $s will actually hold its voltage arounf the 14.8 mark unless the lipos are crappy! Are you set on 4s or could you go higher, 6s would be killer and allow you to gear down some, which seems to help regardless of the motor type.
Not sure if you noticed, but the chassis braces are set wider on the new emaxx than the old one. Maybe a direct to diff setup would fit? An idea?!
