12.23.2007, 01:39 PM
I thought i'd update you guys, I got another pinion, V1. I plan to run them till i can get a V2 set, then they will go to my 3.3 nitro (should make it nasty out if the corners).
To answer some of the questions about the V2 (talked to mike about them), he has the cups for the 8mm input, but they are not included in the diff conversion. he also has modified center shafts for the revo that will run the 8mm inputs of the V2 diffs.
he also has a few pinions for the V1, if you wish to get a spare
