Originally Posted by nl12
see if the transmission will fit on the old version
The new style Transmission mounts different. It mounts to the underside of the chassis instead of going through the frame rails. 4 Bolts is all it has compared to 8 mounting bolts with the old style.
If you want to upgrade an older maxx, get the Chassis and the frame rails to go with the transmission.
